View the source list entries corresponding to each interface and multicast group pair on a router.
You can view IGMP information on a VRF instance the same way you view the Global Router except that you must first launch the appropriate VRF context.
- Select IGMP.
- Select the Igmp Router Source List tab to view the IGMPv3 cache information.
Igmp Router Source List Field Descriptions
Use the data in the following table to use the Igmp Router Source List tab.
Name |
Description |
GroupAddress |
Specifies the IP multicast group address for which this entry contains information. |
IfIndex |
Specifies the interface for which this entry contains information for an IP multicast group address. |
InPort |
Specifies a unique value to identify a physical interface or a logical interface (VLAN), which has received Group reports for this source. |
HostAddress |
Specifies the host address to which this entry corresponds. |
MemberAddress |
Specifies the IP Address of a member that has sent source specific report wishing to join this source. |
Expire |
This value indicates the relevance of the source list entry, where a non-zero value indicates this is an INCLUDE state value, and a zero value indicates this to be an EXCLUDE state value. |
Mode |
Specifies the current member state, applicable to IGMPv3-compatible nodes. The value indicates whether the state is INCLUDE or EXCLUDE. |
MemberExpire |
This value indicates the time until the member for this source expires. |
